Bobs Ten
Date:  10-30-2019
Number of Hours:  3.00
Brief Description:  Install Instrument Panel
1200 - 1500
Install barrier strip busses for lighting. These will be used to bus the three separate lights to one wire from the VPX , as recommended by AeroLeds. Each bank of 3 is bussed together for Nav, Strobe, Ground, and Sync. Three banks of 2 are also bussed to join the landing lights, taxi lights, and recog lights.
These strips were secured to the previously fabricated shelf.
Installed the shelf to the ECU mounts using locknuts.
Install Adel clamp to support aux fuel pump wiring.
Install aux fuel pump relays to shelf using an hardware.
Route antenna coax for VOR/Nav/Loc and GDU460.
