Today I finalized the wiring for the rudder trim actuator. This required removing the LAC board and shortening the rudder position wires and adding an appropriate Deutsch connector.
Next, I began cleaning up the existing wiring. I needed to remove and replace several Adel clamps that are being used for wire guides. The existing ones ended being too small, causing problems running wires and creating a very tight bundle. These were switched to larger clamps.
I ran the trim and actuator position grounds to the ground block.
The overhead lighting power wires were prepared and routed.
