Bobs Ten
Date:  10-21-2019
Number of Hours:  2.40
Brief Description:  Install ELT
1630 - 1854
Today I fabricated an adapter plate for the ELT mount. Vans pre drilled holes will not work with the Artex ELT. I decided to use 063 sheet to make the adapter. Standard techniques were used to match drill and machine countersink for the pre drilled holes. Holes were then located and the adapter was match drilled to the ELT mount.
Nut plates were installed on the adapter plate and clearnce holes drilled in the Vans ELT mount.
The plate was then secured to the Vans mount using flathead AN screws.
The ELT mount was then secured to the plate using AN hardware.
The time spent was due due fabricating the adapter plate twice; the first one did not work as planned.
