I decided to modify the spacers for the backup battery. Instead of 4 separate spacers, there is now two. These spacers are also riveted to the rack shelf. In the event that the battery must be replaced, this mod will make the process much easier. In this same thread, I slotted the forward mounting holes of the battery. This will allow removal of the battery without removing the forward screws; the only need to be loosened. THANKS DAD, GOOD IDEA!
Next I needed to install the top shelf of the rack. Although a good idea, it was MUCH easier to get the forward bolts in without the instrument panel installed. It took nearly 90 minutes to install the mounting bolts. It is now installed and I am pleased with the result. Both units are completely out of the way and easy to connect.
