Bobs Ten
Date:  8-24-2019
Number of Hours:  2.50
Brief Description:  Install RV-10 Jack Points
1530 - 1800
Installed jack points that I sourced from wintermotorsports.com.
I had to remove each main wheel and installed the jack points per the instructions. I purchased two lifting arms in case I want to lift both sides at once.
Next I added the battery sense wires to the bus manager. These wires were connected to pins 2 and 8 on the bus manager control plug. I then removed the additional wires I had previously installed on the main battery posts inside the bus manager.
