Bobs Ten
RV-10
Install Overhead Switch Panel Wiring
1600 - 1830
Today I finished the switch panel pot installation.
Finish cut an sand PCB.
Trim pot actuator shafts to correct length.
Install pots in PCB and solder.
Verify wiring using DMM.
Install wires to PCB breakout points and solder.
Install 6 pin Deutsch connector with appropriate wires, conforming to previously created pin diagram.
Note that only 5 wires were used and a spare (white/green) was installed for future use.
Install aluminum knobs on pot shafts and tighten.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
