Bobs Ten
RV-10
Install Overhead Console Inserts
1600 - 1800
Remove overhead console inserts.
Enlarge mounting holes to provide adequate clearance for minor fit adjustments.
Replace power and ground wires that connect forward and aft inserts. The original wire lengths were too short.
Install inserts using 6-32 SS Torx screws and nylon washers.
Verify fit and operation of the lighting installed in the inserts.
Install wiring to monitor primary and secondary battery voltage at the Bus Manager. These wire will connect to the controller display.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
