Bobs Ten
Date:  6-22-2019
Brief Description:  Install Overhead Console Inserts
1600 - 1800
Remove overhead console inserts.
Enlarge mounting holes to provide adequate clearance for minor fit adjustments.
Replace power and ground wires that connect forward and aft inserts. The original wire lengths were too short.
Install inserts using 6-32 SS Torx screws and nylon washers.
Verify fit and operation of the lighting installed in the inserts.
Install wiring to monitor primary and secondary battery voltage at the Bus Manager. These wire will connect to the controller display.
