Connect forward insert wiring. Install insert in overhead panel. I decided to use SS Torx screws with black nylon washers for the inserts. The Torx heads prevent cam out when installing and the SS screws accent the CF. I only installed a few screws in order to make sure all wiring was operational.
Connect the aft insert wiring to the appropriate wiring from the forward insert. Install insert using Torx screws and nylon washers.
Power the hot battery fuse block and the overhead wiring supply using a 3 amp power supply.
Verify proper operation of all lights. Looks great!
