Secure overhead dome light power wire to previously attached tie wrap mounts.
Connect wire to hot battery fuse block.
Install all four eyeball vents in overhead. I again vacuumed and blew out the dust in the overhead. Intalled each vent using a #135 O-Ring as a spacer. This was necessary due to the minimum mounting thickness of the eyeball vents. The eyeballs were inserted through the console, an o-ring was installed follwed by the nut. The nut was then tightened using the tool that I previously fabricated. As there is not a lot of clearance, the tool was modified to fit.
Next, a verification check was completed on the overhead wiring. Dome light power was tested, as well as, baggage area lighting and glareshield fans. All checks satisfactory.
