Install 6 position fuse block in overhead console. This fuse block will be powered from the VPX. As there will be multiple low power circuits in the overhead, I decided to protect each lighting circuit with a fuse and this fuse block was the optimum solution. To access the fuses, removal of the lighting panel will be required. This poses no issue as all of the low power circuits are for non essential lighting.
Next, the forward overhead panel was marked for light and switch positions. Eyeball lights, dimmers, dome light, and dome light switch are included. The current limiters and PWM dimmer module will also be located here.Final wiring will be completed tomorrow.
