Bobs Ten
Date:  1-24-2019
Number of Hours:  3.50
Brief Description:  Install EFII Harness
1530 - 1900
Today I shortened th engine temp and TPS sensor wiring to final length. This involved removing the pins from the respective metri-pack connecotrs, shortening all wires, installing new pins, and reassembling the connectors.
All pins were crimped and soldered.
Next, I painted the previously fabricated loom supports.
I then fabricated another loom support for the EFII harness. It had to be reasonable substantial as the bundle of wires is fairly large.
Standard techniques were used in fabvrication.
The support was the painted.
