Today I finished fabricating the engine loom supports.
After testing several different materials, I decided to use 063 sheet for the mounts.
Standard techniques were employed for fabrication.
There will be two supports on each side of the engine, secured to the baffle mounting screws. The loom will be secured using Adel clamps. I felt the supports were necessary due to support the EGT/CHT/Fire Sleeve and the injector wires and sleeve.
