First thing today I installed the 1K 1W resistor in the starter annunciator wire, per the VPX install manual. The resistor was soldered and covered with heat shrink. Attached the completed wire to the "I" terminal of the start contactor.
Next, I removed the fuel pressure sensor connector. Again, the stock connecotr is wired with 16 AWG wires. As previously detailed, I fabricated a new connector using tefzel wire. I then reattached the connector to the sensor.
The end of the sensor connector wire was then ternimated with a 3 pin Deutsch connector. This will allow a neat and secure connectionf to the GEA 24 wiring.
Finally, I routed and attached the field wire from each alternator to it's respective regulator. I installed several tie wrap mounts to secure this wiring to the sub panel.
