Bobs Ten
Date:  1-11-2019
Number of Hours:  3.00
Brief Description:  Install Servo Controller, Overhead Wiring
1500 - 1800
Using previously detailed techniques, finish installing servo controller wiring. All potentiometer signal leads, reference voltage, and ground leads were terminated with connectors and connected to the controller. Final wiring will occur once the overhead PCB is complete.
Next the avionics fan wiring was routed and connected to the fans using standard techniques. The PWM fan speed controller was wired at the overhead console, powered, and proper operation of the fans was verified. I had not intended on having a speed control for the fans, however, Dad brought it to my attention that the fan airflow would end up basically right in the pilots face. When tested at full power, this was verified and the speed controller was installed. Thanks, Dad!
The final wiring for the servo controller was terminated properly and connected to the controller. I need to mount the 12V to 5V converter to finish the install.
