I finally received the correct terminals for the Metri-Pack Pull to Seat sensor connectors. This allowed me to eliminate the 16 AWG wires provided with the pressure sensors, reducing the number of splices to zero and making for a neat installation.
I determined the length of the oil pressure and manifold pressure sensor leads and installed a new Metri-Pack device connector on each shielded 3 wire. The GEA 24 wiring diagram was used for reference.
Tighten firewall tie wraps to secure wiring.
Unfortunately, two of the shielded 3 wires wer too long for a proper installation. The remaining time was spent matching the wire lengths in the sensor loom. I had t rewire the 6 pin Deutsch connector to make a neat loom. This gave me the chance to use the TH1A turrent crimper for the Deutsch connector pins. It worked great!
