I altered the shunt fusible links to facilitate wiring of a 6 pin Deutsch DTM connector, as discussed previously.
The DTM connector was then assembled per the Deutsch instructions and ATUM 4:1 heat shrink was applied for strain relief.
Next, I installed several 4 way tie wrap mounts on the firewall. These nylon mounts were riveted to the firewall using 3/16" SS blind rivets. Tie wraps were passed through the mounts and around the applicable wiring. They were not tighten, in order to have access for additional wiring, if needed.
The rivet heades were filled with high temp RTV to seal the heads.
