Finalize routing of antenna cables on the right side of the fuselage.
Install several Adel clamps to secure cable bundle.
Finalize position sensor wirie routes.
Position sensor wires were run through previously installed Adel clamps and added to the bundle.
Run fuel quantity wires to wing root location. Run aileron trim position wires to wing root location. Run elevator trim position wires to tailcone through previously installed conduit.
Some notes:
1. Install more conduits than you think you need. It would have been much cleaner to install the antenna cables throught the tunnel.
2. Realize that is a third party in building the wiring harness, all of the wires will BEGIN at the radio end connector and run outbound to the sensors and antennas.
3. Realize that there will be DOZENS of wires, all converging behind the instrument panel.
