Install Com 1 cable from antenna location to radio location.
Install Com 2 cable from antenna location to radio location.
Install Nav cable. I decided to install the VOR/LOC/GS cat whisker antenna in the vertical stab. This necessitated routing and installing RG 400 cable from the radio location, down the right side of the fuselage and up through the vertical stab. Tooling holes were used to locate and install snap bushings in the fuselage bulkheads. The cable was supported between bulkheads with a short length of conduit that was tie wrapped to a stiffener.
All cables were labeled on both ends.
Next I will run 3 RG 400 cables to the cabin top for GPS/XM antennas. The transponder antenna will tentatively be mounted on the belly, just below the remote transponder.
