Begin organizing, bundling and routing systems wiring through firewall.
Bundled, labeled, and routed heat valve servo wiring and oil cooler servo wiring.
Bundled, labeled, and routed primary and secondary alternator field wires.
The previous wiring for the oil temp, oil pressure, and both shunts was removed. These wires will be connected to the harness on the GEA 24.
I have some questions for Steinair prior to finalizing the J244 connector, so these sensors will wait for those answer. Installing additional wires in the J244 backshell is MUCH easier on the bench than in the airplane.
