Bobs Ten
Date:  11-1-2018
Brief Description:  Install GEA 24 Harness
1600 - 1800
Started installing the engine monitor harness.
Unfortunately, I needed to modify the rack that was previously fabricated due to unanticipated interference. This was accomplished and fit verified.
I also decided to add additional ground tabs to the panel. This was accomplished as detailed for the previous bus. The two ground busses were connected with a .125 x .75 copper bar.
