Bobs Ten
Date:  9-9-2018
Number of Hours:  0.80
Brief Description:  Install Garmin Yaw Damper Mount
1630 - 1718
I decided to install the Garmin Yaw Damper option.
This requires drilling out 4 rivet on the applicable bulkhead in the tailcone. Using a 90 degree drill, I drilled each rivet head, separated the head from the shank and punched the shank from the hole.
I will be using AN 6-32 hardware to replace the rivets and secure the yaw damper bracket.
