Bobs Ten
Date:  8-23-2018
Number of Hours:  1.30
Brief Description:  Install Windows
1330 - 1448
Mask window on the inside.
Mask window edges with vinyl tape.
Break glaze on plexi bonding surface with 320 s/p
Clean all bonding surfaces. VM&P Naptha was used to clean the plexi, as recommended by manufacturer. Clik Bond cleaning wipes were used to clean f/g joggle.
Apply approximately 3/8" bead of Lord A/E 7545 adhesive to the cabin top joggle.
Install window, clamp using previously fabricated cleco clamps and C clamps at the door opening.
Remove excess adhesive.
We let the adhesive set for about about 30 minutes and then removed the inner masking tape.
After about 2 hours, we removed the outer masking tape.
The adhesive coverage looks really good with no noticeable voids.
