Bobs Ten
Date:  8-2-2018
Number of Hours:  1.40
Brief Description:  Install Backbone Wiring
1700 - 1824
I spent most of today working on finances for the final stage of the build.
In the shop, I installed some of the backbone wiring. It turns out that pulling the wires through the conduit is not as easy as one would think. I finally succeeded, pulling the two Essential bus feeds, The Aux DC bus feed, and the contactor switch wires through the previously run conduit. These wires were then routed to the forward fuselage through holes in the fuselage bulkheads. Wiring was protected at each hole with a plastic snap in bushing, per Vans.
