Bobs Ten
RV-10
Install Instrument Panel
1800 - 1930
Connect ECUs to harness wiring.
Installed all Dsub connectors (4x) and Cat 5 cables to ECUs. Cat 5 cables are labeled and follows:
Blue Cable = ECU #1
Gray Cable = ECU #2
Install ECU rack with hinge pin and AN screws.
Install BNC connector on Com 2 antenna cable. Route cable to radio and attach.
Install TNC connector on XM antenna cable. Route cable to XM receiver and attach.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
