Installed Adel clamps to secure left side fuel rail crossover line.
Installed bypass cables. This required adjusting them for full and correct range of motion. I installed wheel collars to act as safety stops for the valve. One collar provides a solid end point for closing the valve. The other collar prevents the cable from pulling through the B nut in the event of a loose set screw in the B nut. The Cable Safe fittings were tightened to secure the sheath.
Next, the cable bracket was installed in the CF side panel and the panel secured in place with clecos and screws. Tomorrow I will add Adel clamps to secure the cable sheath in the cabin tunnel area.
