Bobs Ten
Date:  3-17-2018
Number of Hours:  1.00
Brief Description:  Install Throttle Quadrant
1524 - 1624
Install quadrant to tunnel cover.
Install tunnel cover assembly, lower console, and insert.
Adjust quadrant for best fit to insert, clamp in position.
Remove tunnel cover assembly, lower console, and insert.
Match drill two lock bolts in quadrant mount brackets. This was done to ensure the quadrant does not vbrate loose from is position as the other four screws resdie in adjustment slots.
Install nut plates using standard techniques.
Install quadrant, mount, and brackets to tunnel cover using AN hardware. Complete installation by installing locking screws.
Install tunnel cover assembly, verify fit.
