I received the quadrant insert blank from Aerosport yesterday. I needed the blank dur to the custom quadrant; it is a two lever quadrant instead of three and the pre cut insert hole was too wide.
Trim perimeter of insert using bandsaw and permagrit tools.
Clamp insert to lower console, match drill nine holes as indicated on the insert using #40 drill, cleco as drilled.
Debur and smooth all edges.
Layout cut lines for quadrant on insert.
Using permagrit tools and standard techniques, remove insert material to fit quadrant.
Install lower tunnel cover assembly and lower console.
Install insert with clecos, verify fit.
Trim as required to achieve a satisfactory fit.
Match dril top center hole through insert, console, and panel using #40 drill.
