Bobs Ten
Date:  3-2-2018
Number of Hours:  3.20
Brief Description:  Install Aerosport Panel
1412 - 1442 1524 - 1806
Install forward part of tunnel cover.
Trim the conduits to facilitate wiring. The right side was cut short beneath the tunnel cover to allow the fuel pressure and fuel pump wires to be fed through the conduit. The left conduit was secured along the left side of the tunnel with tie wraps. It was cut just aft of the fuel selector. This will allow wiring from the aft tunnel and armrest to be run through the tunnel without removing the throttle quadrant or mid tunnel cover.
The carbon fiber insert for the fuel selector was prepped, sanded, and clear coated for install.
Next, I began trimming the lower console for the throttle quadrant. I called Aerosport and they are sending an uncut quadrant insert to fit my two lever quad.
Debur and smooth quadrant mount plates.
