Counter sink two top subpanel mount holes for flush screws.
Clean up cutout edges. I left a nominal 3/4" flange. I will need to cut it back to 1/2" once I receive the printed insert file from Steinair.
Fit lower console.
Several iterations were necessary as I decided to use the aft rudder torque tube mounts. This required trimming the side panels to clear the torque tube.
Trim area where the lower console mates to the panel to improve fit.
