Bobs Ten
RV-10
Engine Baffling
1500 - 1830
Clear coat engine mount covers.
Install engine mount covers. A small bead of RTV was applied to the cover flange to ensure a seal. Screws were secured with blue loctite.
Trim baffle material for governor gasket, punch screw holes.
Install governor gasket and doubler using 6-32 hardware.
Install internal lock washers on baffle mount screws.
I opted to paint the intake plenums.
Prep the plenums for paint.
Apply adhesion promoter, per instructions.
Apply 2 coats of rustoleum 2X Metallic Aluminum paint per instructions.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
