Bobs Ten
Date:  12-14-2017
Number of Hours:  1.50
Brief Description:  Install Oil Door
1330 - 1500
Remove all packing tape from cowl and oil door.
Remove oil door.
Trim and smooth f/g to facilitate proper door fit.
The SORIC definitely stiffened the door. Unfortunately, there were some areas that did not bond. These areas were ground out, carefully as to not damage the underlying molded door.
F/g cloth was cut and wet out in separate pieces.
These pieces were applied to the door and verified to be bubble free.
