Bobs Ten
RV-10
Engine Baffling
1400 - 1600
Remove foam mold from governor shroud.
Rough sand and clean bonding points.
Rough and clean inside of cowl.
Final fit the upper inlet ramps. I bonded a few scraps of f/g to the inlet ring to assist in alignment.
Apply a seal coat of epoxy to iside forward 1/3 of cowl.
Mix epoxy/flox/cabo.
Apply epoxy/flox to flange of inlet ramp.
Position and clamp ramp to inlet.
Cleco ramp flange to cowl.
Remove excess epoxy.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
