Bobs Ten
RV-10
Engine Baffling
1330 - 1542
Sand and smooth previous modification to right intake plenum.
Install plenum.
Locate and mark area of plenum to remove to provide adequate clearance with cylinder head fins. This is a small area aproximately 2" x 2".
Roughen surrounding plenum and prep for f/g.
Using the previously detailed procedure, infltae balloon inside plenum. Apply pipe insulation to cylinder head, setting clearance.
Mix epoxy, wet out 3 layers of 9 oz cloth.
Apply f/g to plenum.
Install plenum with clecos.
verify fit and smooth f/g layup.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
