Bobs Ten
RV-10
Engine Baffling
1324 - 1630
Remove cowl.
Remove intake plenum assembly.
Match drill three equally spaced holes in left intake flange, cleco as drilled.
Remove clecos.
Slip left intake plenum from center plenum.
Remove vinyl from flange.
Sand and smooth new plenum flange.
Install center plenum and intake plenums.
Install cowl, verify fit.
Make initial cuts to #2 baffle.
Using f/g flanged sheet from showplanes, fabricate intake plenum forward mounting plates.
Match drill plates to #1 and #2 baffle mounts.
Adjust f/g mounts until satisfactory fit was attained.
Mix epoxy, wet out 2" and 3" tape.
Apply 4 layers of f/g tape between intake plenum and f/g flange mount sheet.
Verify fit of plenums to cowl.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
