Bobs Ten
Date:  8-18-2017
Number of Hours:  2.20
Manual Reference:  47
Brief Description:  Install Cowling
1524 - 1600 1930 - 2106
Remove Cowl.
Remove locking pins from skybolt receptacles.
Install aft lower cowl insert.
Locate and mark centerline on aft fairing.
Remove excess flange to rough measurement.
Locate and drill flange mounting holes, 7x.
Measure approximate relief for nose gear fairing.
Remove relief area.
Verify fit.
Scribe nose gear fairing on aft fairing.
Remove material and verify fit.
Repeat steps to fit aft fairing around nose gear leg fairing.
Once fit was achieved, match drill fuselage bottom to aft fairing, cleco as drilled.
