Tape machined skybolt cleco adapters to brackets. These adapters are machined to fit the skybolt brackets and provide a center hole to drill. A cleco is then inserted to clamp the cowl as a skybolt fastener would.
Using a flashlight, illuminate the cleco adapter from behind the cowl. This provides a fairly accurate bright spot on the outside of the cowl. Drill the spot and secure with cleco. I started from the top middle and worked down each side of the top cowl, alternating left and right, cleco as drilled.
Cleco the nose of bottom cowl to secured top cowl.
Using a block, support aft of bottom cowl.
Using the same procedure as above, install clecos starting at the bottom, working up the sides, alternating left and right.
