Continue to install the Skybolt brackets as previously detailed.
Passenger side top was completed. The final bracket needed to be shortened, yielding around 3" spacing at the top center. Due to the shortened center bracket, an adjacent bracket was removed and a flange was created to capture the shortened center bracket.
Next, the passenger side lower firewall flange was completed. I am not sure of where the cowl will finally lay, so I may need to add one more bracket.
