Bobs Ten
Date:  6-9-2017
Number of Hours:  1.00
Brief Description:  Install Oil Cooler Lines
1730 - 1830
Remove Straight Oil Nipple from engine.
Install AN823 45 degree nipple using Loctite 567 thread sealer.
Install oil cooler lines between AN fittings.
All lines were made by Tom at TS Flightlines.
Replace silica dessicant in dehydrator plugs. The dessicant turns pink when saturated so I decided to replace it with new silica. One at a time, I refilled and replaced the dehydrator plugs. I purchased an extra plug for this purpose. I removed one saturated plug and immediately installed the extra. I then refilled the saturated dessicant and repeated the process. This allowed minimal time for moist air to reenter the cylinders.
