Bobs Ten
Date:  5-19-2017
Number of Hours:  1.00
Brief Description:  Install Alternator
1700 - 1800
I needed to remove and reinstall the alternator.
The B&C alternator kit that was sent with the engine turned out to be for a single pulley ring gear. The engine that I have has a dual pulley, so the alternator was not aligned properly.
A call to Barrett and B&C was made and the dual pulley bracket was supplied.
Removed alternator and bracket.
Installed new bracket, verified alignment of alternator pulley with ring gear pulley.
Torqued bracket bolts and safety wired them.
Installed alternator pivot bolt qand verified alignment.
I need to fabricate a 5/16" thick bushing to support the tension arm as the alternator has been moved aft.
