Install EFII Dual ECUs and mainfold pressure sensors.
Modify previously fabricated hinged shelves between the sub panel and firewall to provide for rudder trim arm clearance and installation of the dual ecus and maifold pressure sensors.
Match drill shelve for ecus.
Debur all holes.
Install ecus in stacked configuration usinge threaded spacers and 1/4-20 bolts. All bolts secured with blue loctite.
Match drill shelf for manifold pressure sensors using #12 drill.
Debnur all holes.
Install sensors using AN3 hardware.
Verify fit of forward top fuselage assembly.
Remove assembly to dimple and c-sink missed rivet holes.
