Bobs Ten
RV-10
Install Oil Cooler
1506 - 1618
Smooth edges of cooler mount opening using files and s/b wheel.
Verify fit of cooler.
Install nut plates in fabricated angle for top of mount.
Cleco then rivet top mount angle to cooler mount, using SS blind rivets.
Vacuum cooler mount of all chips.
Secure cooler to mount using AN3-3A bolts and washers.
This modification was relatively easy and should provide additional cooling capacity compared to the standard size cooler.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
