Bobs Ten
Date:  2-19-2017
Number of Hours:  1.40
Brief Description:  Install Gear Leg Fairings
1312 - 1436
Remove tape holding stiffeners to gear legs.
Sand edges of stiffeners to match gear legs.
Prep legs for epoxy.
Mix and apply epoxy/low density filler to stiffener/gear leg joint. This will eliminate any potential voids in the cloth wrap around the gear leg and stiffener.
Trim, grind and smooth aft wheel pant cutout for stiffener using permagrit tools, and s/p.
Measure and cut 9 ounce f/g cloth in preparation for gear leg wrap.
