Bobs Ten
RV-10
Install Nose Gear Fairing
2100 - 2200
Drill brackets using #36 drill, tap for 6-32 screw, 8x.
Drill fairing using #28 drill for 6-32 screws.
Rough inside of fairing using 60 s/p.
Tape brackets to prevent bonding of epoxy.
Clean inside of fairing in preparation for epoxy.
Mix epoxy/milled glass/cabo.
Apply epoxy to brackets and start waxed 6-32 screws through fairing, 8x.
Using tongue depressor, create filet between bracket and fairing.
Install fairing and brackets on nose fork.
Install 3/8" bolts to secure brackets.
Install forward fairing.
Snug 6-32 screws against fairing. Verify no fairing deflection or distortion.
Verify position of fairing in pitch, yaw, and roll while snugging 6-32 screws.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
