Bobs Ten
Date:  1-14-2017
Number of Hours:  0.80
Manual Reference:  48-18.2
Brief Description:  Install Nose Gear Fairing
1600 - 1648
Locate and mark brackets for drilling.
Once again, install right bracket, aft wheel pant, right bracket, forward pant.
Position, check, and verify fairing position in pitch, yaw, and roll.
Match drill fairing and bracket. Holes were drilled and pinned, one at a time, verifying fairing position after every hole was drilled. Repeat 8x.
Verify fairing position in pitch, yaw, and roll.
Remove fairing and brackets.
