Bobs Ten
Date:  12-10-2016
Number of Hours:  1.50
Manual Reference:  48-15, 48-16
Brief Description:  Install Nose Gear Fairing
1542 - 1712
Contniue to grind and smooth forward and aft fairings to facilitate a satisfactory fit using permagrit tools.
Locate and mark flange holes per plans by laying the measurements out on painters tape then applying the tape to the forward fairing.
Tape forward and aft fairings together and match drill flange holes using #40 drill, cleco as drilled.
Separate fairing, grind flange for fit.
Cleco fairings together, check fit.
Repeat to improve fit.
After several iterations, fit was satisfactory.
