Bobs Ten
RV-10
Install Main Gear Wheel Pant
1200 - 1400 1812 - 2012
Remove forward and aft pants.
Clean up the excess epoxy mix using permagrit grinding burr and 60 s/p.
Install right aft pant.
Mix epoxy/milled glass/cabo per plans and create pocket around axle extension. Extension was previously covered with packing tape.
Apply and smooth epoxy mix around all mount pockets.
Final drill left pant bracket using #19 drill, debur.
Locate nut plates and match drill mounting holes to bracket using #40 drill, debur.
Machine c-sink bracket for flush rivets.
Cleco nut plates in position.
Rivet nut plates using p-squeezer.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
