Bobs Ten
RV-10
Install Main Gear Wheel Pant
1230 - 1442 1730 - 1842
Fit and drill aluminum bracket spacer.
Fit and drill wheel pant in position, pitch, roll, yaw.
Remove pant.
Tap brackets per plans.
Install pant and verify position and fit.
Remove pant.
Aggresively roughen inside of pant near mounting holes.
Apply packing tape to mount bracket to prevent bonding.
Mix epoxy/milled glass/cabo.
Apply epoxy mix to mount locations.
Install pant, using screws and clecos.
Verify position in pitch, roll, yaw.
Apply epoxy mix to areas in left pant that were missed during it's fitting.
Install left pant.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
