Bobs Ten
Date:  11-4-2016
Number of Hours:  2.30
Manual Reference:  48-5, 48-6
Brief Description:  Install Main Gear Wheel Pant
1436 - 1654
Remove left pant, grind epoxy pocket edges smooth.
Per plans, fit forward and aft right wheel pant, grinding where necessary to facilitate clearance with gear leg.
Once again, the time spent making the jig was well spent.
Locate and drill axle extension mount hole coincident with the flange joggle, install bolt.
Remove forward pant, verify fit.
Install front pant, cleco in position.
Verify pant position in pitch, roll, and yaw.
Locate and drill holes in wheel pant and mounting bracket at previously marked sites. Insert awls as drilled.
Verify wheel pant position in pitch, roll, and yaw.
