Bobs Ten
Date:  10-24-2016
Number of Hours:  1.20
Manual Reference:  48-6.3
Brief Description:  Install Main Gear Wheel Pant
1618 - 1730
Verify fuselage level.
Verify wheel pant position in pitch, roll, and parallel to fuselage center line.
Per plans, locate and drill holes through wheel pant and bracket using #36 drill, pin with awl as drilled.
Verify all wheel pant measurement, after drilling holes.
Remove wheel pant.
Per plans, aggressively rough inside surface of wheel pant in specified locations using 60 grit s/p.
